Which sound card is better?
imported_Moses
18
I have and Audigy 1 and needed a sound card for my other so I bought an Audigy 2 Value OEM, which one is better? I put the Audigy 2 Value OEM in my main comp and I am not to sure if it is better or worse....
Any comments / suggestions?
imported_Moses
18
I seem to notice a bit more fuzz with the A2 value than I did with the Audigy 1 in some of my mp3s but I am not to sure if it is just me listening harder for it than I used to.
alcoholbob
6,390
468
The Audigy 2 ZS is the "true" Audigy 2, in my opinion.
The "plain jane" Audigy 2 is in some ways a backwards step from the Audigy 1. While published SNR specs are higher, these are under very controlled conditions.
The Audigy 2's main fault is a faulty amplifier, that easily clips and distorts at high master volume settings. Turn it down to around 70-75%, and it should be "technically better" than the A1. The A2 ZS fixed these distortion problems.
imported_Moses
18
Crap guys I have heard a pop or a crackle here and there. I am going to take back the Value asap and get an Audigy 2 ZS Gamer.
inveterate
1,504
DUDE<<< STOP RIGHT THERE STOP>>>>> BUY.com AUDIGY ZS 2 PLATINUM for 60 buxxxx... FUc Gamerz.
