Which power supply for my setup
Daryl1148
I'm currently using a Thermaltake 420watt supply for my asus a8n-sli deluxe. My computer keeps resetting every so often when i play games for a while. What kind of supply do you guys reccommend and how can i tell the difference between a regular atx supply and a 24 pin atx supply? I'm looking into purchasing a 24pin atx supply but i'm not sure exactly what they are called. I'm running 2gigs of ddr3200 ram, xfx6800ultra, and a amd 3500 cpu.
If you want one of the Best power supplies for your rig, try the new Enermax series with dual 12Volt lines. Excellent for high end systems with video cards such as yours!
If this doesn't solve your problem, then it's not power supply related! 😉
Enermax 470Watt Noisetaker series
