Which parts should I upgrade?
Discussion in 'General Hardware' started by ek89027, Dec 21, 2012.
  1. ek89027
    ek89027 Junior Member
    Dec 21, 2012
    Hello, I am trying to upgrade my computer to enhance my gaming experience. I am wondering which part/parts I should upgrade(Should I consider buying a brand new computer instead of upgrading individual parts?). I am trying to play demanding games such as Planetside 2, Rome Total War 2, and Witcher 2 on high graphic without suffering lag. The below is the computer spec and my resolution is 1920 x 1080.
    System Information
    Operating System: Windows 7 Ultimate K 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.120830-0333)
    Language: English (Regional Setting: English)
    System Manufacturer: Gigabyte Technology Co., Ltd.
    System Model: GA-890GPA-UD3H
    BIOS: Award Modular BIOS v6.00PG
    Processor: AMD Phenom(tm) II X4 965 Processor (4 CPUs), ~3.4GHz
    GPU: AMD Radeon HD 6870
    Memory: 8192MB RAM
    Available OS Memory: 8188MB RAM
    Page File: 4088MB used, 12286MB available
    Windows Dir: C:\Windows
    DirectX Version: DirectX 11
    DX Setup Parameters: Not found
    User DPI Setting: 120 DPI (125 percent)
    System DPI Setting: 96 DPI (100 percent)
    DWM DPI Scaling: Disable
    DxDiag Version: 6.01.7601.17514 32bit Unicode
  2. Loading...
    Similar Threads - parts upgrade Forum Date
    How Often Do You Upgrade Your PC Parts? General Hardware Jul 1, 2016
    Should I Upgrade Parts or Rebuild? General Hardware Nov 3, 2015
    Upgrading my Workstation with 5930K, Upgrading Gaming Rig with Parts from Workstation General Hardware Dec 12, 2014
    Upgrade some Parts or New MircoAtx Build? General Hardware May 20, 2014
    Current PC worth upgrading, or just buy all new parts? General Hardware Jan 31, 2014
  3. riversend
    riversend Senior member
    Dec 31, 2009
    477
    First off, fill in a couple of answers from the sticky at the top of the forum:
    What is your budget?
    What country do you purchase from?
    Do you need another copy of Windows if you swap out the mobo/cpu/ram?
    Finally, for Rome 2 no one can say what you will need, but I would guess that Shogun 2 is a pretty good indicator if you have it now, although obviously Rome 2 is likely to be a bit more intensive.
    Are you playing Planetside 2 and Witcher 2 now? If so, what are you unhappy with.
    Regardless, need your budget info and where you are buying from with links if another country.
  4. ek89027
    Dec 21, 2012
    Thank you for the reply and sorry for not including some of the important details.
    Budget is roughly $500. I am planning on purchasing the parts from newegg/amazon and other internet sources. (In the US most likely or in Canada depending on the price.) No I do not need another copy of windows. I plan to buy the parts relatively soon probably before the end of January. No brand preference and I do not plan on overclocking it. As for the games I have mentioned, the amount of lag makes playing those two games at high graphic or in some cases medium graphic impossible.
    #3 ek89027, Dec 21, 2012
  5. Torn Mind
    Torn Mind Diamond Member
    Nov 25, 2012
    3,065
    30
    The course of action I would recommend would be to first buy a higher tier video card from a brick and mortar company like Walmart or Best Buy so you can return it in case you don't get what you desire. The 6870 is below the 69xx, 78xx, and 79xx Radeon cards and it is equivalent to a GTX 560.
    Should a higher tier graphics card fail to produce the desired results, then the CPU is a bottleneck and needs to be upgraded. An i5 system would be appropriate should this be necessary.
    Whatever upgrade you make will cost and arm and a leg.
  6. lakedude
    lakedude Golden Member
    Mar 14, 2009
    1,641
    Starting out with a graphics card sounds like a good plan. At 1920 x 1080 the HD7850, GTX660 or HD7870 are excellent choices.
    I'd not upgrade the CPU in that MB. You might look at a new intel CPU and MB.
    Intel Core i5-3570K $220
    ASRock Z77 Pro3 LGA 1155 Intel Z77 $90
    HD 7850 $170
    or grab a killer GPU now (like a GTX670 or HD 7970),save some money and upgrade your MB CPU later...
  7. aaksheytalwar
    aaksheytalwar Diamond Member
    Feb 17, 2012
    3,389
    Get a 3570k and 7850
  8. DSF
    DSF Diamond Member
    Oct 6, 2007
    4,902
    Before you buy anything I would do some quick tests.
    Run the games you're trying to play at high, medium and low settings (including resolution - turn that down as well) and see if there's a performance difference. If so, a new video card would help. If not, you'll need a CPU upgrade as well.
  9. ek89027
    Dec 21, 2012
    Thank you for all your comments, I will try and run one of the games right now and experiment with the resolutions/graphics and find out if the graphic card is indeed the problem.
    Once again, thank you. You guys really helped me out. (Even if the video card is not the problem I will still look at them.)
  10. mfenn
    mfenn Elite Member <br> Currently on <BR> Moderator Sabb
    Jan 17, 2010
    22,403
    :thumbsup: My guess is that PS 2 is CPU-limited and TW 2 is GPU-limited, but we can find out for sure with this method.
