I cannot decide which card to keep, so please help me decide within 7 days. Both of these cards are ATI original, built by ATI. I like to play games with good quality graphics and speed, but speed is not as important as quality since I think the speed is fast enough with either card. The competition is between:
-Radeon 8500LE 128MB @ 275/275Mhz. Connections, S-video out, CRT, dual display both TV and CRT monitor.
-Radeon 9000 Pro 128MB. Connections, Coax video out, CRT, DVI-I, dual display both TV and CRT or both CRTs.
The second question is which one would display better on TV? Coax or S-video? Is there a bit difference between the two connection types?
Is it true that the Radeon 9000 Pro has DirectX 8 while the Radeon 8500 does not really support DirectX 8? Which card will support DirectX 9 better?
System specs:
-P4 1.6AGhz@2.24Ghz
-Epox 4G4A+
-Two Maxtor 40GB 7200rpm, 2mb buffer.
-One Maxtor 80GB 7200rpm, 2mb buffer.
-Two Samsung 512MB DDR PC2700.
-48x12x48 Liteon CDRW drive.
-16X DVDrom Liteon.
-Santa Cruz.
-On board ethernet chip
-WinTV PC401 Stereo.
-Firewire card.
-V.90 USR hardware gaming modem
-100MB zip drive.
-1.44Mb floppy.
-Two 8cm high speed fans in front.
-1 9cm fan at the back.
Please help me decide as I can only keep one.
System specs:
-P4 1.6AGhz@2.24Ghz
-Epox 4G4A+
-16X DVDrom Liteon.
-Santa Cruz.
-Firewire card.
-100MB zip drive.
-1.44Mb floppy.
