Which of these (2) 350 watt power supplies?
Scoobyd00
A friend is giving me one of his power supplies and told my take my choice.
Both are 350 watt.
The Enermax cost more new, but does that mean its the better of the 2?
Here are the output if that means anything
Antec Output: +3.3V@28A;+5V@35A;-5V@0.5A;+12V@16A;-12V@0.8A;+5VSB@2A
Enermax Output: +3.3V@32A, +5V@32A, +12V@26A, -5V@1A, -12V@1A, +5VSB@2.2A
Thanks guys
Scoob
The Enermax would be your only choice if you were going to be using an Athlon 64 rig, a higher end P4 rig, or overclocking. It has better rails generally all around, and is more than sufficient on the 12v rail to support higher end video cards and most any tweaking you'd want to do to your system, if you're into that.
If your rig is a simple budget celeron/sempron/axp rig, you can settle with the Antec and be fine.
The rig will be for DVD ripping/folding Its a 3.2c overclocked just a little to 3.5 all it has for a video card is a little asus 9600xt. Running onboard sound. Will have 2 large hard drive and 2 opticals though.
Board is a asus pc4800-e
