AnandAusten:
Forgive me for being too lazy to learn the HTML-esque functionality of the message board, or use it. In my line of work, HTML is about as valuable to me as say, rollerblading knowledge, so I've never bothered with it.
You can post 100 links to cpu scaling, but the bottom line remains the same:
You actually recommended Raj buy a cpu that's only 133MHz faster than the one he has. Even if they were free, the gains realized from such an upgrade wouldn't be worth the 10 minutes it would take to install the "upgrade".
"Of course the 9500PRO has other benefits but the DX9 is one of the worst"
I didn't say it was the BEST reason, but a 9500Pro is faster than a 4200, and has DX9 support. Even if they were exactly the same in performance, wouldn't it be better to have Dx9 than not?
"It's lame to think that all (or any significant amount of) 4200 cores are rejects and defects from the 4400 or 4600 and even the ones which are will likely hit 270."
It's also lame to make purchase recommendations based on highly variable OCing speculation. What if he has a minitower case with zero airflow that turns into an oven when he fires it up? What if he does get a chip that was appropriately speed binned? Here's the difference between my advice and yours: If his parts don't perform at the speed on the box, he can take them back to the store for an exchange, HONESTLY. If he doesn't achieve your OCing results, can he tell the person at the counter "Some guy on Anandtech said I should be able to run this 30% above spec, it doesn't, can you give me another to try?"
"Rollo it seems you need to justify your own purchases but instead you come off as sounding a little too rightous and full of yourself."
I never need to justify my purchases, period. My purchases are seldom justifiable, I just like to play with new parts. This year I had a GF3, GF4 Ti4400, R8500 Retail, R9700 Retail, and a V5 in my box. I would be happy with any of them, they all had interesting aspects.
However, he asked what card would be best for his system, and not underperform, and the 9700 pro is the ONLY answer to that question. All of the rest "underperform" by comparison. Can you post any links that show any other card beating the 9700 with a system like his?
"the way you bark on and condemn other opinions with a single flimsy link is a little sad IMHO."
The way you advise him to make irrelevant cpu upgrades and the worst choice for a vga upgrade is a little confusing IMHO.
