Which monitor should I keep for photo editing?
eljay
8
I just bought a PC that came with an Acer LCD and I also have my old Gateway LCD. One of them has to go. Please help me decide which one should I keep for primarily photo editing and office productivity/tasks.
#1: Gateway FPD2185W
Specs: http://support.gateway.com/s/manuals/Monitors/8511263.pdf
Panel size: 21 inches (diagonal)
Panel type: 21 inch viewable TFT active matrix S-PVA
Anti-glare coating
Pixel resolution : 1680 x 1050 (native) (75 Hz)
Pixel pitch: 0.0106 x 0.0106 inches (0.270 mm x 0.270 mm)
Aspect ratio: 16:10
Brightness: 300 cd/m2
Contrast ratio: 1000:1
Viewing angles: 178° horizontal, 178° vertical
Response time: 16 ms or 8 ms (gray to gray)
Frequency: Horizontal: 31-81 KHz Vertical: 56-76 Hz
Lamp type/life: 50,000 hours
Colors: 16.7 million
Connections and inputs:
Analog (VGA): 15-pin mini d-sub VGA
Digital (DVI-D): 24-pin DVD-D (supports 480i, 480p, 720p, and 1080i). Includes HDCP (High-bandwidth Digital Content Protection)
Composite video
S-Video
Component Y Pb Pr (supports 480i, 480p, 720p, and 1080i)
USB 2.0 B-type (input)
USB 2.0 A-type (output x4)
Audio power (only for the Gateway speaker bar accessory)
Power consumption: 75W
#2: Acer P206HV (20" LED)
Specs: http://www.support.acer.com/acerpanam/MONITOR/2010/Acer/P206HV/P206HVsp2.shtml
Series Name: P206HV
Display: 20-inch (diagonal) Widescreen LCD
Active Display Area: 17.43 × 9.81 inches (442.80 × 249.08 mm)
Pixel Pitch: 0.276 mm
Maximum Resolution: 1600 × 900
Maximum Refresh Rate: 60 Hz
Screen Treatment: Non-Glare
Panel Technology: Twisted nematic (TN)
Response Time: 5ms
Contrast Ratio: Dynamic: 5,000
Brightness: 200 cd/m2
Viewing Angles (CR = 10) Horizonal: 170° Vertical: 160°
Number of Colors: 16.7 million
Input Signal: VGA
DVI (w/HDCP)
Speakers: Two 1W Speakers (optional)
VESA Wall Mounting 100 × 100 mm
Power Consumption : (Energystar On) 27.2W (typ.)
I know both of these are not great LCDs, but sounds like the Gateway is a better bet for photo editing and the Acer would do better with gaming and movies, correct?
Thank you!
corkyg
Elite Member | Peripherals
27,370
240
I would try photo edit with one, then try the exact same edit with the other and let my eyeballs be the judge.
eljay
8
That's not a bad idea and very obvious one. I'll try that.
I've read that PVA panel should be better than TN at color reproduction. Plus there's more pixels and brightness with the Gateway panel.
Lorne
873
Agree to trying them both, So far the Gateway looks like a better choice for higher resolutions.
