OK I have narrowed down my monitor purchase to these three models.
The 955DF and 950P can be had for sub 250, but the 900IFT is at ~370.
The 950P and 900IFT specs are great and very similar.
The 955DF has lower specs, but both the 955DF and 900IFT are flat screen monitors, while the 950P is not.
I want a flat screen monitor, but is it worth the lower specs? I won't be running over 1280x1024 so I don't think that the specs really matter that much. Or does it not matter whether it's a flat screen or curved? Or should I just spend a little more and get the best of both worlds?
I would greatly appreciate your opinions and any comments if you have had any experiences with any of these monitors and your recommendations.
I really don't want to spend a whole lot, I'm looking for a "shortert" depth monitor if possible without sacrificing performance.
The 950P is a little bit deeper then the other two just to note.
