Which monitor out there with built in speakers is the best?
inachu
2,387
I am sick and tired of the wires.
My temporary fix is using my 42 inch tv as a pc monitor and it works well but it is too big and want a regular pc monitor instead.
MagnusTheBrewer
IN MEMORIAM
Jun 19, 2004
24,122
1,594
Wrong forum but, in general, you're looking at a case of "lesser evils." There aren't any monitors with good built in speakers.
piasabird
17,168
60
Most monitors that have speakers do not have a decoder that can run off of an HDMI cable/signal. It usually involves running another cable for the speakers.
DigDog
14,629
3,003
what magnus said.
also, you can buy logitech 2.1 pc speaker/sub combos for $50 which are surprisingly good.
wires are a necessary evil -deal with it.
Ben90
2,866
Why not just bundle the wires together with the one that comes out of the monitor?
corkyg
Elite Member | Peripherals
27,370
240
Agree with Magnus except that this is the correct forum. Monitors are peripherals. So are speakers. Having said that, why not checkout wireless speakers?
inachu
2,387
I may have to go to the extreme and bust up some drywall to drop the wire behind to hide it all.
It is a total rat maze of wires under my desk.
corkyg
27,370
240
Rather than bust up the drywall, get a length of PCV pipe and use it for a wire conduit. That would neaten things up a bit.
DigDog
14,629
3,003
^^ i second the post above mine.
you can paint the pipe as well to hide it. you can also buy semi-soft pipes designed to hold cables, they have a slit on the side (which is screw-like, so stuff doesnt fall out) which allows you to just slip in the cables when you need.
