You will not see a large benefit over a KT133A unless you use DDR RAM with the KM266. You might measure a benefit with a benchmark, but you'll be hard pressed to see it by that 'seat-of-your-pants' subjective feeling.Thanks for reporting the benchies! Nice to hear there is some gain going with this newer chipset. I am also considering about buying this board (the M7VIG Pro) to replace an aging unstable KT133a board.
Hmm, I was also thinking that going from ATX to MATX might alleviate any power problems I was having with powering a bigger mainboard.Originally posted by: Peter
... and besides (yet again) replacing the mainboard because "it is unstable" usually isn't the right thing to do. In the vast majority of cases, the root cause for the lack of stability is elsewhere - bad RAM is quite common, so are overstressed power supplies that age quickly, as well as clogged up CPU fans and heatsinks (especially with smokers).
Bad thinking. mATX might reduce some trace length here and there, by putting the same # of devices on a smaller foot print, but it is your devices that consume power, their relative trace length or distance from each other is an insignificant factor here for power consumption. Timing and termination issues, maybe, but not power consumption.Hmm, I was also thinking that going from ATX to MATX might alleviate any power problems I was having with powering a bigger mainboard.
There is always a possibility of a failing capacitor, flakey voltage regular, or power source on the motherboard. It happens. But I would test out my RAM and other components before blaming the motherboard.Okay thanks guys, I'll try attacking the problem from a differnt direction.
Originally posted by: tcsenter
There is always a possibility of a failing capacitor, flakey voltage regular, or power source on the motherboard. It happens.Okay thanks guys, I'll try attacking the problem from a differnt direction.
v5.x (aka K7S5A pro) has an additional USB 2.0 controller on the PCI bus
Hmm, SIS745 is now quite mature, has SIS stopped producing it or is the cost still high? One would think if ECS wanted to really give the K7S5A a boost and extend market life, migrate it to SIS745's DDR333, add USB2.0, 6-channel sound, and charge the same. JMHO!and it's just being refreshed, v5.x (aka K7S5A pro) has an additional USB 2.0 controller on the PCI bus, with 4 ports, and the chipset's USB 1.1 controller's six ports are on expansion headers. Everything else (except for the legacy game port) is still there.
Of course, USB 2.0 on PCI is noticeably slower than chipset integrated USB 2.0. Still, nice move.
