Hi,
I am gonna buy an 800Mhz Pentium 4 with the Asus P4P800 (Springdale) mobo, and was wondering which of the following RAM by Kingston would be my best choice:
First of all, is HyperX there best RAM as they seem to have different types on there site.
And then, which one from this list (see: http://www.kingston.com/hyperx/default.asp)
- KHX3200/256
- KHX3200K2/512 (2 - 256MB)
- KHX3200A/256
- KHX3200AK2/512 (2 - 256MB)
First of all, what's the difference between the 3200 and 3200A types and for dual-DDR operation on the Asus P4P800, do you really need to get hold of the kits or should 2 sticks of KHX3200/256 also work fine (in other words, are only the modules in the kits completely the same or will this also be the case if you order 2 KHX3200/256 sticks)?!
PS: on that page of HyperX RAM they also mention: "Note 1: HyperX is high performance memory and may not be compatible with your computer. Please check your system specifications to ensure compatibility." Which system specs do I need to check as they don't mention it and when could there be compatibility problems?!
- KHX3200/256
- KHX3200A/256
