Which is better, low voltage or high voltage memory?
Pez D Spencer
Banned
Nov 22, 2005
401
While browsing for some RAM on Newegg I noticed the voltage listed for various memory. It seems to be 1.8 on the low end and 2.2 on the high end. Which is better low or high voltage? I know a LITTLE about overclocking and based on what I know I would guess that you want higher voltage memory right? I say this because a higher voltage memory means that it'll be able to withstand an increase in the voltage as you overclock more and more right? Or wrong?
Thanks.
Fayd
7,970
www.manwhoring.com
high end memory is low end memory with upped voltage in order to improve timings.
well... it's more complex than that, but basically, yeah.
JustaGeek
2,827
Lower voltage RAM is better handled by most of the motherboards, and it should be less prone to failure, hence it is better.
If the voltage rating is too high, the MB might not boot the first time, and you might have to find a low voltage stick to boot, change the voltage in BIOS, and only then install the High Performance, High Voltage memory.
My RAM is rated at 2.0V-2.1V at 800MHz and 4-4-4-12, and that's why I decided to get it. Most brands are rated 2.2V at these speds and timings.
cmdrdredd
27,052
357
Both of the above responses are somewhat incorrect.
memory rated to 1.8v uses lower quality ICs such as Promos or Elpida. They also will not overclock as high and will not usually accept higher voltages to achieve tighter timings and higher speeds. Memory that is rated above 2.0v usually uses Micron IC (typically D9GMH). They overclock further and can achieve tighter timings.
Today's BIOSes and motherboards do not have the same problems as the early P965 boards with memory rated to 2.0v+. They will boot at 1.8v and you simply adjust the voltage and timings manually.
So knowing this you have to ask yourself 2 questions. 1) will you need to overclock your memory over the stock rated speed and 2) how much are you willing to spend for the stock operation.
The second question may confuse you, but I'll make it easy. You can buy DDR2-800 for say $60 and it will work but may not get an overclock much above the stock speed and adding voltage will not work. Or you can buy DDR2-800 for $100 and it may overclock better and adding voltage (within reasonable values) will yield more headroom. Or you can spend over $130 for DDR2-1066 (PC8500) and then you have alot of overclocking room even without actually overclocking your memory.
It depends how far you want to go and what you're willing to spend to do it.
JustaGeek
2,827
Generally speaking, all the memory available on the market today has SPD's written and programmed to boot at 1.8V, often with the timings relaxed enough to make it possible - like 5-5-5-15-2T for DDR2 800.
After the initial boot, the user is required to enter the BIOS setup and adjust the frequency/voltage/timings manually.
That's all I was trying to convey in my post above. I have read many posts written by people with memory rated at 2.2V, unable to make that initial boot.
Their only solution was to find a "slower" memory to make the first boot, adjust the voltage, shut off the computer, and only then install the "High Performance, High Voltage" memory modules.
cmdrdredd
27,052
357
This doesn't happen anymore with the new boards and with the latter BIOS revisions shipping on the various motherboards today. It's pretty much a non factor anymore.
You're on the right track though. Going back to what I mentioned about P965 boards, they had an early problem with some memory and not boothing up because they required 1.8v operation. The motherboards needed BIOS updates to be compatable with different types of memory. Like I said, today it's almost a non factor.
JustaGeek
2,827
LOL I wish I could say that about my P5N-E SLI.
Just had to "downgrade" the (June) 0608 to (January) 0401 BIOS - the MB would just refuse to boot!
Never had a problem with the original 0202, and have no problems with 0401.
But 650i and 680i chipsets are rather difficult to deal with.
SerpentRoyal
Banned
May 20, 2007
3,517
I don't know of any IC vendors that could build 1.8V DDR2 1066 and sell them at a reasonable price. High quality 1.8V DDR2 800 should be able to compete with DDR2 1066 at the same speed and timing. My 512MB 1.8V DDR2 800 Kingston ValueRAM is uber stable at 602MHz with 2.1Vdimm and 5-5-5-18-2T. Higher voltage = Hotter IC. My advice is to go with quality 1.8V DDR2 800. Avoid those DDR2 800 sticks with 2.0-2.1V rating.
I'm not an expert in DRAM fab, but I know enough about the technology to work as a consultant for a very large fabless semiconductor company in S Cal.
JustaGeek
2,827
Could you elaborate?
My G.Skill HZ series is rated 2.0 - 2.1V, and it is a great memory. Crucial Ballistix is rated at 2.2V, and it is undoubtedly a great memory. I do not think I understand your statement...
Mr Fox
876
The Days of fat body D-9s are long since passed... The good D-9 chips now days are more resistant to higher voltages, and have been thru over a year of product development.
You still pay for good chips and will as time goes on... it is based upon engineering/design prowess, and fabrication quality assurance, along with the use of Six Sigma Methodology that separates the fecal matter from the Cream of the Crop...
Silicon is the Constant, and everything you do in the Input side of that process shows in the output side of the product.
The Voltage that you can Hit JEDEC Specs at is all Relative especially if you can hit tighter timings, and not effect warranty returns.
Most of the older low voltage chips were 5-5-5-15 and there were also some 4-4-4-12 and that was on the lower density chips...
Now with the newer high density Microns 4-3-3-10 Voltage 2.2 - 2.25V also Motherboard Manufacturers are understanding the demands, and releasing BIOS at 2.0 v as Optimized default...
This has all come about due to simple Product Development, and lessons learned.
SerpentRoyal
Banned
May 20, 2007
3,517
Higher voltage chips will generate more heat. You'll need good air flow to keep these higher voltage chips happy. When 2.1V chips can consistently delivery DRR2 1300 speed, then I will be sold on the "newer technology". As of today, I have no problem pushing quality 1.8V DDR2 800 modules up to 550-600MHz range with 2.1Vdimm and 5-5-5-15-2T timing. These modules have lower initial cost and better compatibility with many MBs.
There's no need to push the FSB above 480MHz with any C2D rig, unless you want to boast about the lowest SP time. CPU core speed is still KING.
My definition of a great memory is the ability to hit 460MHz at 4-4-4-12-2T timing with 2.0Vdimm and a unit cost of $25/GB. Naturally, the RAM should be rated for 1.8V operation at default settings.
cmdrdredd
27,052
357
Show me a memory that can hit 550Mhz every time without fail that doesn't use Micron (rated at 2.0v+). I want to see it. Even D9 cannot guarantee that.
SerpentRoyal
Banned
May 20, 2007
3,517
Go buy the Kingston N5 DDR2 800 and learn something new. Why worry about 550MHz when the sweet spot for P35 boards is under 500MHz?
cmdrdredd
27,052
357
Is it too hard to get through you're head that some people overclock their memory because they can and they want to?
Sweet spot my ass...overclocking is a hobby for some people.
SerpentRoyal
Banned
May 20, 2007
3,517
It's your $ to burn. A lot of people seek a balance between price and performance. Go back and re-read the OP's questions. Is this person looking for 550MHz RAM? I'll let others figure out who has a "hard head".
cmdrdredd
27,052
357
I'm pointing out a key flaw in marketing for memory. They don't say what IC is used and the general rule of thumb is that memory rated around 2.0v or higher has Micron IC which will overclock higher. If you are going to overclock your memory this is something to look at beyond the price.
That's all. For those of us who want every ounce of speed, you have to pay more to do it.
Mr Fox
876
One of the things that he does not take into consideration is what has to happen in order to make a higher density IC operate
Micron : D9GSV is the current high density IC of Choice 2.0-2.2V@5-4-4-12
This is similar in rating that the popular D9GMH chips have, which are also based on the revD die. The difference lies within the density, and the number of banks.
To make a 2GB module with 16 chips, a 1Gbit chip must be used (1Gbit = 128MB). For 1GB modules with the same number of chips, 512Mbit chips are used. D9GMH is a 512Mbit chip, arranged in 64Mx8, which means each 'cell' is 64Mbits, and there are 8 'cells' per chip. 64*8 = 512Mbit.
To increase the density of the chip, either the number of cells (width) or size of the cells can be increased, or both. If the width is increased, less chips must be used per module. The total width of the module must be 64 or 128 for desktop memory. Using 16 chips, the 1GB and 2GB sticks in question must both use memory chips that have a width of 8. The only remaining option to increase the density is to increase the cell size from 64Mbit to 128Mbit. As such, D9GSV is arranged in a 128Mx8 layout.
However, there is an obvious tradeoff with doubling the size. Take a look in history at CPUs. When dual core processors were launched, they were found to be less overclockable than their single core counterparts. There are a few reasons for this, but the primary reason is that the dual core CPUs have twice the number of transistors. More transistors means more area, which in turn leads to a higher probability of defects that will limit clock speed.
Memory has the same exact problem, being based off very similar CMOS technology that CPUs use. For each bit in a DRAM device, there is a transistor and a capacitor. Every single transistor and capacitor has to be able to switch on and off, as well as drain or charge quickly, or data corruption will occur. So by doubling the capacity of the revD die from 512Mbit to 1Gbit, it is only natural to expect overclocking performance to drop significantly.
The 1Gbit chips have a trick up their sleeve though: Double the number of banks.
From Micron's technical documentation:
As with standard DDR SDRAMs, the pipelined, multibank architecture of DDR2 SDRAMs allows for concurrent Operation, thereby providing high, effective bandwidth by hiding row precharge and activation time.
In simple terms, DDR2's addressing methods allow multiple memory accesses at once, but only if they are in different banks:
A subsequent ACTIVE command to a different row in the same bank can only be issued after the previous active row has been closed (precharged). The minimum time interval between successive ACTIVE commands to the same bank is defined by tRC.
A subsequent ACTIVE command to another bank can be issued while the first bank is being accessed, which results in a reduction of total row-access overhead. The minimum time interval between successive ACTIVE commands to different banks is defined by tRRD.
DDR2 devices with 8-banks (1Gb or larger) have an additional requirement - tFAW. This requires no more than four ACTIVE commands may be issued in any given tFAW (MIN) period.
While the tFAW latency restricts the advantages, doubling the number of banks improves memory efficiency a bit. Splitting the data up into more banks increases the probability that two given sets of data are not on the same bank. Thus, a higher probability that when two access are made, the data for each are on different banks. As a result, total access time is reduced, improving latency and effective bandwidth.
So, the 1Gbit chips may not overclock as well, but at the same settings should provide slightly higher memory performance.
stephan.b2hv
www.b2hv.com
Intel recommends you don't go over 1.65v with your RAM on X58 chipset, or it could damage the memory controller on the CPU.
"Low voltage just means the voltage to run stock speeds is 1.65v or less.
Blain
OCZ says low voltage is 1.65v.
The DDR3 JEDEC voltage standard of 1.5v would indicate that "low voltage" is below 1.5v
