N ntauzin Junior Member Apr 11, 2002 9 0 0 Apr 11, 2002 #1 Should I use copper or aluminum tubing for a water-cooled CPU? Does it matter? Is one metal better than the other at thermal dissipation? Thanks-
K Kelvrick Lifer Feb 14, 2001 18,422 5 81 Apr 12, 2002 #2 Don't most people use plastic tubing? I think that'll be A LOT easier considering its flexible. I haven't seen anyone use metal tubing yet.
2 2Cool Senior member Oct 13, 1999 649 0 0 Apr 12, 2002 #3 Copper is your best option, as it is less brittle, a bit more corrosion resistant, and easier to solder (if you need to) than aluminum. I have seen a few hardlined water cooling systems, makes for a clean install, but you do lose flexibility.
S Strafe Senior member Oct 11, 1999 558 0 76 Apr 12, 2002 #4 Whatever you do, don't mix metals. If you're using copper waterblocks, use copper tubing. Mixing = corrosion.
R RagManX Golden Member Oct 16, 1999 1,219 0 86 Apr 12, 2002 #5 Connect all your components with silicone tubing. Use the same metal for all components (all copper or all aluminum). RagManX
G greg Platinum Member Oct 9, 1999 2,842 0 0 Apr 13, 2002 #6 Use silicone. Why? Heat dissipation is good, but let it dissipate OUTSIDE of the case, not inside where you are trying ot keep cool.
