- May 1, 2001
- 3,004
- 3
- 81
I ask, as my Denon AVR3300 Receiver has only 1 Coaxial Input, but 2 (or 3?) Toslink Inputs. Right now I use my Toshiba DVD player with its Coaxial audio cable to the Denon, thus, using the Only Coaxial Input on my Denon. But my Soundblaster Live Original card comes with the Digital I/O riser card, that supports Optical S/PDIF out, with Coaxial cables. So what I'd like to do is hook up my sound card and PC system to my Denon Home Theater so it can play my games, and DVD's in Dolby Digital Surround sound 5.1, if the media will support it on my PC. But if I do this, I will have to change my DVD player to Toslink Audio cable. Do you think I would loose Audio quality while watching DVD's on my TV and Toshiba DVD player?
I Could buy a Coaxial Cable to Toslink converter at like Radio Shack; but I suspect, I would loose a lot of the audio quality?
So basically, it all boils down to; is it better use your DVD player at home with a Coaxial Cable to the Receiver or Toslink Cable?
Opinions, Please. Thanks
