Which is best upping the FSB or Multiplier to get the same speed ?
Nuggs
98
Is it better to up the fsb or just the multiplier to get the same speed, And I mean better for the CPU not performance.
sao123
12,653
205
CPU multipliers are almost always locked...
however its ever overclockers dream to up the FSB and decrease the multiplier.
Nuggs
98
ive got the barton 2500 with the multipliers unlocked, but i cannot seem to get a stable overclock upping the fsb but just upping the multiplier to 13 and the voltage to 1.7 and the system is well stable running at 2.16ghz just want to know is this safe ?
bjc112
11,460
If it's a Intel Chip then it's locked (excluding those lucky enough with the enginerring sample ) Wing ;)
Most AMD chips "B" in a nForce 2 chipset will be unlocked..
But i agree, it is the overclockers dream to bump the higher FSB, it increases bandwidth a LOT... Especially those running QDR 1000mhz..
:D
sao123
12,653
205
in order for the best overclocking you want syncronized overclocking.
if you want to up the FSB it may be in your best interest to change the multiplier also.
EXXADURATED EXAMPLE (not possible) ...but apply the theory to your case...
Current P4's run at 3200Mhz (16x multiplier) & 800Mhz FSB (200 quad pumped.)
The next stable FBS would be either 233 (933 effective) or 250 (1000 effective)
In order to have a stable CPU you want it syncronized, and keep it at approx the same speed.
Case 1: 233 FSB, the most stable syncronized CPU's for this speed would run at approx... 3266.
Set the multiplier to 14.
Case 2: 250 FSB, the most stable syncronized CPU's for this speed would run at approx... 3250.
Set the multiplier to 13.
Here we go Steelers, here we go...
Are you really from the area? or just a wannabe fan?
:beer:
bjc112
11,460
:beer:
Oh my I will be a Steeler fan forever... I just moved from pittsburgh to Phoenix... ( 18yrs in Pitts )
Steelers are tooo hard.
:D
Wannabee :p ya right..
FFactory0x
6,991
FSB definitly untill you hit a wall then the multi. The FSB will give your mem bandwidth which is invaluable for gaming and other appz
deadseasquirrel
1,736
IMO, it comes down to memory and motherboard. i've got a kt333 with samsung pc2700. while the memory *might* get to 200fsb, my mobo doesnt have a 1/6 divider so my agp/pci would be way outta spec at anything over 190fsb.
so i decided to play it safe and do both fsb and multi. chip default was 133x11 (XP1700), and i run at 166x13.5 (XP2800).
KF
1,371
Yes.
What is happening is that almost all the CPU is operating at the same frequency and so is at the same stress and temperature. Just the interface to the external electronics is at a different frequency, the front side buss frequency. Running the FSB slower is easier on external circuitry, but neither more nor less damaging. It is easier to maintain a cleaner signal at a lower frequency.
sao123
12,653
205
Where did you get this from??? He said...
Any sort of overclocking & voltage raise definately add heat & stress.
Yes.
Not necessarily ...I just read this article at ace's hardware. Increasing the voltage in a CPU could increase your chances of a MB/CPU failure (worst case) by a factor of 10x, if not properly cooled.
Read the article yourself.
http://www.aceshardware.com/
