I'm going to remove the stock HS/fan on a 32Mb VisionTek GeForce GTS. I was wondering which of the following should I get as a replacement:
Copper Video Heatsink
BlueOrb
Both are confirmed to fit just fine with the clips that come with the card.
Also does anyone know if VisionTek uses just heatsink paste or a thermal epoxy on the GPU? What is the best way get the sucker off if it is glued on?
Finally does the card use 4 or 8 memory chips? I want to mount some small heatsinks on the memory to get a little extra juice out of the card.
Windogg
BlueOrb
Windogg
