Hey guys ... I need your help again
In my last thread I sought opinion on whether to get the AIW 7500 or AIW 8500. Based on the feedback, the AIW 7500 seemed to be a better solution for me since I was not very keen on getting high end graphics, but TV out quality was more important for me ... so I got the AIW 7500 from Newegg last week for $129 (since it seemed to be of better value).
However, this morning I saw that CompUSA has the AIW 8500 (NOT 8500DV) on sale right now for $149 ... so I couldn't resist and bought this card as well
I still haven't opened the box because I need to do some research and then keep the better one and return the other.
The $30 or so price difference is not important for me, and I still retain the position that TV out quality and TV Tuner quality is more important for me than high end graphics. Apparently both the 7500 and 8500 uses the same chip (Rage Theater) for TV out ... so I don't expect the basic TV out quality to be sigficantly different between the two. However, the TV tuner used in the two cards is completely different. The 7500 uses the old tried and trustworthy analog Philips TV tuner (and I can attest that the TV reception is great with this), whereas the 8500 uses a new silicon based solid state TV tuner ... whose quality is not yet proven (at least I don't know about it).
So, now I need to know which of these two cards have a better TV TUNER ? If any of you have any experience with both or either of these two cards, I would very much appreciate you dropping a line here with your feedback.
If I quickly run down the specs, the AIW 8500 clearly seems to be a better choice for me ... but I would like to get some feedback from you guys before finally deciding which one to keep.
AIW 7500
I will be using this card in a Home Theater PC, which will be used mostly for TV viewing, PVR (Tivo like) function, and playing back DivX and DVD movies. However, I *do* plan to occasionally play games on this PC as well.
So what do you think - which card should I keep ?
Thanks in advance for any feedback !
AIW 7500
- Radeon 7500 GPU
- Analog TV Tuner
- 64MB DDR VRAM
- Radeon 8500 GPU (clearly better than the 7500)
- Silicon Solid State TV Tuner. Don't know if better than the Analog Tuner
- 128MB DDR VRAM
