Which fans can go horizontally? CM690 case fans, H70 fans...
Triggaaar
I've got a CM690ii Adv case, with 3 case fans included (2* 140mm and a 120mm)
A Corsair H70 with 2 included fans
A new Thermalright TY140 and 2 Scythe GT AP15s
I don't know what types of fans they all are, so does anyone know if any of these can't be position horizontally?
Thanks
You can position the fans anyway you want as long as the airflow goes in the desired directions. These fans always have two arrows on the fan itself: A vertical one showing the direction of the airflow and a horizontal one telling you which way the fan turns.
Thanks for the reply. There are some types of fan that don't work properly (wear out or something) in placed horizontally though aren't there?
Yeah, that's the kiddy, thanks 🙂
I know the Scythe GTs are ball bearing fans, good in an orientation, but I have no idea about the fans that came with the CM690. Does anyone know?
I think the ones that come with the 690 are just stock coolermaster fans, you can look them up on newegg. Pretty sure they are sleeve though.
Well looking at the cm website they all seem to be sleeve, but one comes fitted in the horizontal position. I'll just ignore it and if it breaks I'll replace it.
In my 690 that took about a week before this annoying click-click appeared. Replaced the bottom 140mm with the Thermalright 140mm fluid bearing model. Six months later there's no stock fans in the case. Kinda wish you could by a case without fans and save $5. ;-)
All fans can be run horizontally or vertically.
The problem is with sleeve bearings and positioning. But you have to understand what a sleeve bearing is.
Sleeve bearings resemble a paper towel cardboard inner roll....the cardboard tube left after the towels are used. The shaft the fan is mounted on slides inside the sleeve bearing with a few drops of oil applied. Simple, right?
There are a couple of weaknesses though. First weakness is the shaft tends to pick up grit, dust and slowly move that junk down into the sleeve, making a grit paste that grinds on the sleeve's surface making it wear quickly and generate horrible noise when running. Another weakness is when mounted horizontally, the oil tends to migrate down the shaft and bearing, eventually leaving the shaft and sleeve almost dry and unprotected and not lubricated.
Ball bearing systems, all the hydro-type bearing systems, etc., all address these weaknesses and tend to work much better, last longer and be indifferent to mounting positions. The down side to these bearing systems is they tend to be slightly louder when running than sleeve bearing systems.....at least initially.
Thanks for the informative post, learned something there. :thumbsup: I'm about to change out all the fans in my Antec 900 and this certainly helps.
