Which Fan Speed Controller out there is compatible with the Tsunami?
hugejazz
27
My tsunami case (with window) comes with 3 fans which are all connected with 4 pin molex connectors. The sound coming off the case is quite loud, so I need a fan speed controller to calm the fans down a bit.
However, most of the stores I visited only sell controllers with 3 pin connections. And my TT case uses 4 pin molexes. So can someone please refer me to a controller which can be used with the Tsunami.
ericlala
387
what u need is the 4 pin <---> 3 pin cables because they try to save space on the controller
or if u have the right connectors, just redo the wires
BigCoolJesus
Banned
Jun 22, 2005
1,687
Originally posted by: hugejazz
is it possible convert your own molex 4 pin into a 3 pin?
yes, but it wont look to good
if you do do it though, remember, the 2 black wires from the 4 pin merge into one black wire, and the red and yellow stay seperate
mindwreck
1,585
the sunbeam one might still include it. Mine came with 3 converters but that was about 2 years ago when i bought it. I've never seen one that uses 4 pin connectors, it just takes up too much space. I would just get some 4->3 pin converters. $.99 @svc
