- May 2, 2015
- 16
- 0
- 66
Hey guys,
first off, here's my system:
Ncase M1 case
Maximus VII Impact
i7 4790K lapped / delidded
apogee drive II
ST30 240mm radiator
2 x Cougar Vortex CF-V12HP fans
Samsung 850 Evo 256GB
16GB Hyper X 1866
If you've seen the Ncase M1, the 2 fans sit on the side. Mine are intake fans, forcing air through the rad and onto the MB and then out the top.
I am wondering what is the best config for efficiency. Right now I have the pump hooked up to the CPU fan header, and each fan hooked up to a port on the Asus Coolhub. I can control each port through the BIOS.
Which is more important to cool the CPU during waterclocking? Increasing the speed of the pump as it gets hotter or increasing the speed of the fans on the rad?
The motherboard is getting kind of hot. During stress testing in Aida 64, it is getting up to 45C after 10 minutes. One of the fans pushes air right onto the motherboard, should I increase the speed of that one?
How much quieter are the Gentle Typhoon AP-15s? The cougars aren't too loud at 800rpm (the lowest they'll go with Q-fan) but they are far from silent.
Also, how hot is too hot for an SSD? Mine is sitting at 40C right next to the PSU.
Ncase M1 case
Maximus VII Impact
apogee drive II
ST30 240mm radiator
16GB Hyper X 1866
 Facebook
Facebook Twitter
Twitter
