Arkaign
- Oct 27, 2006
- 20,736
- 1,377
- 126
OMG! The e8400 kills the E5200! Why even put this up!
He asked Stock! but even at the same clocks, the e8400 kills the e5200, it's just bad bad bad comparing it to the X3 for any reasonable measurement.
This is as close as you are gonna gt. And its very very close to 100% accurate:
http://www.anandtech.com/bench/Product/119?vs=66
This actually is 100mhz slower for the X3, so your results would be slightly better. But as you can see, the X3 440 eats up the 5200 by a long shot. Expecially when you get to the timed benchmarks (in seconds) and the games.
So the 445 would be even better. The AMD x3 Wins by a long shot!
Oh yeah, for sure at stock the 445 would be fine. Either is great.
For overclockers, the E5200 easily hits 3.5ghz (I did it on a cheap cooler with a crappy $50 G31 motherboard), and at that clock speed it'll be faster than a stock 445, and about equal once both are overclocked.
Stock, higher clockspeed is better. Overclocked, it's kind of a wash, they're both well behind the curve, but the C2D with lower cache (2m/3m/4m models) is about even with Athlon II clock for clock. C2D with higher cache and higher FSB usually pull even or ahead of PhII clock for clock. This all assumes that they have the same amount of cores, but the Tri-Core AMDs usually only showed benefits over dual-core AMDs in encoding.
