- Oct 10, 2002
- 3,561
- 206
- 106
I have had enough with the insufficient stock cooler on my Intel 4790K CPU (mounted on asus Z97-AR mobo in a normal desktop tower case) and want something that is quieter. I had never wanted to get an aftermarket one before because i do not want to take the mobo out just to install a cooling fan. But now I am willing to do that. What do you recommend, should i get a Cooler Master Hyper 212 EVO or something else like:
ZALMAN CNPS8X Optima 100mm Long Life Bearing HIGH PERFORMANCE CPU
or this one:
Reeven BRONTES CPU cooler, 100mm low-profile type, INTEL/AMD
or?
I am a slickdealer so price is definitely going to be an issue, my limit is $40 after rebates and discounts.
so in summary my criteria are
or this one:
or?
- quieter than my stock HSF (duh!)
- on the cheaper side
- hopefully something that is easy to install
