Ok, I'm upgrading my PC, and I've decided to go Athlon 64. Simple enough choice. After looking at prices, I figured the Athlon 64 3000+ is really cheap, and I can probably overclock it to at least3200+ range I'm hoping.
Now here's where I need help. I need a motherboard with an AGP slot since I'm using an old Radeon 9700 Pro and can't really afford to upgrade right now. Anybody have any experience overclocking with these boards? I just don't want to get a board that won't let me overclock, a mistake I won't make twice. ( I bought a locked 2500+ barton 2 years ago but couldn't overclock it past a 190 FSB due to the motherboard not being able to handle it)
RAM shouldn't be too mucb of an issue, right? I've been reading that it doesn't matter if the memory divider is 1:1 like it did for older cores, so i was just gonna get a GB or two of the cheaper stuff...
And finally, heatsinks. Will I need to upgrade from a stock heatsink? How much of a difference should I expect if I do upgrade? I don't suppose there's anyway to tweak an Aero 7+ heatsink/fan to fit the 939 socket, eh? ^_^
Thanks for all your help! Peace
EDITED to reflect a slight change of the questions.
