Which case/power supply?
orwell84
67
Which case and power supply?
I am trying to decide between a Cooler Master Cavalier or a Thermaltake Tsunami VA3000SWA. My budget is about $100. I just need something roomy with good cooling...nothing fancy. Anything else in that price range that you might recommend?
Also I was considering the Enermax WhisperII 535 watt power supply. Any reason not to go with this.
My system will be:
AMD 4000 San Diego
DFI LanParty Neo4Blahblahblah
EVGA 7800 GT or GTX
don't think I will be going for SLI.
Thanks for the help.
Heckler 5th
267
you'd probably get better cooling with the tsunami. not really fair tho cuz it's almost twice as expensive as the cavalier. personally, i prefer cases that can draw fresh air in through the front of the case toward the back. the side fan will definitely help.
good choice on the PSU. should work great for you. and please don't get corsair RAM for that DFI...
