Which case is better for cooling?
TheSpy007
I like the looks of the p180 more but i would like this case to move air quick. I could either get the 900 for 100$ or the p180 for $50 after mail in rebate. Which one would you guys pick. I would be using the tuniq tower but ive read that it will fit in both cases.
If you like the looks of the P180, then get it. With the $50 you save you can get an extra case fan you put in one of the drive bays.
I have the P180 and I enjoy it, though truth be told, I don't see it all that much because it's under the desk. But, it has the two fans in the upper rear of the case for evacuating the hot air and one at the bottom for blowing over the HDs and I added a second in the middle drive bay (couldn't use it because the 8800GTX was too long) for more air movement. I have no complaints...well...one:
It is hard as hell to get the covers on or off. The tabs are plastic so you have to use caution as to not break them off.
Hands down...
The Antec Nine Hundred is a hardcore gaming case and pwns the P180 when it comes to cooling!
That's the whole reason Antec came out with it - the P180 can't keep up with the new game cards... 😀
