Which card to get for triple 24 inch monitor?
ylin0811
Hello everyone,
If one wishes to max out all the settings in every video game on triple 24 inch monitors, then would a single GTX 980Ti be powerful enough? or should they just buy dual GTX 970 and use SLI?
Thank you.
I would say 2 gtx980ti's would be enough for every game.
Your talking 3 1080p monitors right?
welcome to Anandtech forums.
How does duel or triple monitor work? What does my computer require to be able to use these feature. I'm not using 2 monitor to play games, I'm using one monitor to surf the web, use game guide, interact on forum and another to play game? Does that effect gaming performance if you use 2 monitor instead of 1?
Single r9 295x2 would be far cheaper and AMD supposedly has better multi-monitor support. I'd wait till AMD launches new cards though to get a proper view of the market.
If you want to max out EVERY game 2 x 980ti is current choice I think.
This^^^
Do you have the monitors yet? If not, make sure they have Displayport.
