Which card is right for me?
Batmansfriend
Hi all, I'm new here.
Thinking of upgrading my graphics (from Radeon 9200) and wondering which is the best bet for my system which is:
AMD Athlon 2800+ (T/bred)
MSI KT4 Ultra 333FSB
768MB PC2700
120GB ATA
Soundblaster Live value
The options seem to be:
Radeon 9600 Pro or XT
Radeon 9700 Pro (a few OEMs around in the UK)
Geforce 6600 standard (non-GT)
Radeon 9800 Pro
Geforce 6600GT
I'm looking for good 2D performance as well as 3D with a good DVI implementation as I am also looking at getting an LCD. Reviews point to the GF 6600GT being the most capable card here.
The questions are:
Would the GF 6600GT be overkill for my system?
Would one of the other (lower cost) cards make for a better balanced system?
Would it be a good idea to go to 1024MB RAM?
Would a Soundblaster Audigy 2 improve performance
Many thanks.
I'd go with the 6600gt, if you can spare the $200. It's not overkill for your system, it's a well-balanced midrange card. As for the memory and soundcard, I dont think it would be worth it, you wouldn't notice much difference in performance, if any.
