Which cable do I need to connect my two routers and how should I connect them together?
TazExprez
689
I am going to connect my two routers together and wonder whether I should use regular or crossover ethernet cable. My two routers are a Linksys WRT54G Version 1.1 and a Linksys BEFSR41 Version 2. My WRT54G will be connected to the cable modem. I will use the BEFSR41 to connect one of my other PC's and PS2's. The BEFSR41 will be receiving the Internet from the other router and it has a WAN port, 4 regular ports, and an UPLINK. What port should I connect the cable coming from the WRT54G? Also, which type of cable should I use? I would prefer to use a regular ethernet cable if this is at all possible. Thank you for any help.
JackMDS
29,545
422
If you just want you use the second Router as an additional switch.
Use a straight cable connection a regular port on the wrt54 to the uplink of the second router.
You need to configure the second router to be a dumb switch.
The instructions are for Wireless but the principle applies to any Router.
Link to: Using a Wireless Cable/DSL Router as a Switch with an Access Point
:sun:
TazExprez
689
Thanks a lot for your help. Now I'll order the cat 6 cable and the data cable staples. I wonder if anyone makes a white cat 6 cable and white data cable staples? I currently have other wires and data cable staples ran, but none of them are white. Thanks again.
