Which blue LED fan should I get? WITH PICS!
Zclyh3
Banned
Oct 16, 2001
582
Here are the selections:
Antec's Blue 3 LED fan
Specs:
Size 80 x 80 x 25.4 mm
Weight 71.5 gm
Fan Speed 2,600 rpm (avg.)
Volumetric Airflow 34 CFM
Static Pressure 0.12 inch H2O
Acoustic Noise 30 dBA (at average rpm)
COST: $7.81 at buy.com with free shipping
OR
SVCompucycle's blue 4 LED fan
Fan Dimension: 80x80x25 mm
Air Flow: 32.5 CFM
Rated Voltage: 12 V
Rotation Speed: 2500 RPM
Current Draw: 0.17 A
Noise Level: 28.3 dBA
Power Consumption: 2.00 W
Connector: 3-pin w/ RPM
Bearing Type: Ball Bearing
Accessories: 80 mm finger guard
Life Time: 40,000 hours
fan screws
3pin to 4pin adapter
COST: $7.99 with no shipping (I live within 4 miles of them)
Please post your thoughts and why!
aphex
Moderator<br>All Things Apple
Moderator
Jul 19, 2001
38,572
Antec.
Ive had 2 SVCompucycle fans crap out on me :)
GoingUp
16,720
how loud are each?
EDIT: Nevermind im a moron....I overread the lines..... I have a 80mm delta that whines at about 50DB I cant wait to get a new led fan thats cheaper..
GoingUp
16,720
Originally posted by: SuperSix
Buy.com can rot in hell..
THey sell Antec 20% below disty cost.. :(
Isn't that a good thing? Doesn't it mean its cheaper to buy then?
