I would suggest one no bigger than 1.5" in diameter. Hope this helps.
I agree but the OP doesn't have access to a drill press, and freehand with a forstner bit absolutely suck on most wood, but it might be fine on soft poplar.a forstner bit would give a cleaner hole than that speedbore bit or the hole saw.
if you have a drill press that you're using, i highly suggest the forstner bit.
else, speedbore bit.
holesaw, but you don't want to use a seperate pilot bit, use the bit on the hole saw.
A forstner bit will likely burn up on a hand drill. The outside of a forstner bit is like a cylinder and will rub if you rock it while drilling. 1 1/2" spade bit might work, but at that size it's going to be really unstable if you run into a knot or when you exit the board. The hole saw will be painless.
Forstner especially if you have a lot of holes to drill. The hole saw is alright but if you have a lot of hole to drill then cleaning them out is a PITA.
when you stop buying at harbor freight, get back to us.
LOLZ at the forstner bit spelled right, then the hole saw recommended because it must not be a cylinder.
LOLZ at you probably never using a hole saw because you obviously don't understand how they work.
Actually metal and wood, I own a full set (not harbor freight junk)
Like a boss
You said you don't have a drill press. Paddle bit or hole saw.Is 32 a lot? I'm leaning pretty heavily towards the forstner at this point.
Seriously, thanks for all the input everyone. However if I'm going to have to clean out the holesaw that many times it's going to get annoying. In regards to the bit burning out I'll be cautious but put some money towards a higher quality bit just to be sure.
I've got 2 sets. Very handy in the right circumstances.I use a bit brace for that kind of thing. I suppose you don't have one, but they're worth acquiring. You can find them at flea markets, and antique shops for not too much money.
Edit: What are you making?
Shelving. Aluminum pipe for uprights with kee klamps to hold the actual shelves in place. I plan on drilling straight through the wood so I can adjust the shelves whenever I feel like it. Meaning, when I buy more crap to put on them.
