- Sep 6, 2003
- 11,699
- 29
- 91
As title states, which AMD CPU/GPU will work in a B550 M/B? This machine will be used strictly as a HTPC running Netflix, YoutubeTv, Discovery+ & Amazon Prime (I think that is all my wife has us set up for...)
For gaming I have a X570 MB / RYZEN 5 3600 (I thought this was a 2nd gen chip but Newegg lists it as a 3rd gen? Is that correct? / 16GB RAM / WD BLACK 500GB SN850 NVMe GEN4 PCI-E / RX 580 8GB GPU / SEASONIC 750W 80+ GOLD PSU which I know is overkill but a SEASONIC 550W 80+ Gold will be going in the HTPC. Both machines will have 16GB of PC3000 (or possibly faster, but I have 2 sets of 16GB PC3000 DDR4 RAM sitting here already - would I gain much by going faster or more RAM in the gaming rig and give it 32GB -insert speed here- DDR4 RAM in them, but I think the machines should be fine with 16GB each as the gaming rig will be running a 1920x1200 via DVI connection and the HTPC will be running a 1929x1080 display via HDMI (that had been acting up lately, so that may be moved to a 4K display, after all is built, and if the HTPC display is still acting up, a 4K will be swapped out for the now known to be defunct 1080p display.
As far as the HTPC goes, if a CPU/GPU all-in-one chip is not the best route, I do have a RX570 4GB GPU - you guys and girls direct me to the best outcome that will last me the longest, and I know the HTPC will last a decent amount longer than the GAMING RIG. The HTPC will also act as the Home Server running a WD BLACK 500GB SN750 NVMe GEN3 PCI-E & A PAIR OF RAID 1 SPINNERS, encrypted at my place and then upload to AWS where they will get encrypted again and possibly to a third place which I have not figured out yet whether it be a Safety Deposit Box or another Cloud Based setup (important data).
I have taken about a 7 year hiatus from gaming (the last game I played was Battlefield 4 on a used i5 2500k / NVIDIA 560 TI).
I see CPU prices climbing quickly so I would like to pick one up for the HTPC ASAP.
***** NEW INFO 05/10
Regarding Intel, looking at a 10400/F mated with a B460 based M/B (need to verify the M/B I have inind will be OK a PCI-E 3, 4x (I think that would be the correct syntax 🤔, anyway the main drive will be a WD SN750 NVMe, then 2x 5400GB spinners in RAID 1) and if the built in GPU will work with a single display upto UHD 4k, or will I need to use a RADEON RX570 4GB?
Is there a better Intel setup that would be more cost effective than what I am looking at? The HTPC will not see any gaming, just upto ripped/non-compressed (I own the originals) 4k, UHD Blu-Rays and streaming services, so max 4k video & HD Audio.
***** END NEW INFO 05/19
Appreciate the time and knowledge,
Bob
Bob
