Which 19" LCD Monitor?
shd17
16
Trying to decide between the Viewsonic VA912B and Benq FP91G+ and they both have pretty much the same specs so which one do u guys think is better?
xtknight
12,974
I'd go for the BenQ FP91G+. What is your price range though? There may be something better.
shd17
16
nothin' more than 260~270. and also are the quality of the two brands about the same too?
xtknight
12,974
OK...go for the BenQ FP91G+ then. Given my experience with ViewSonic I'd take BenQ any day.
Vinnybcfc
216
I have had a awful Viewsonic CRT so if this is based on brands then anything beats Viewsonic.
dwdty9
535
i would never buy a 19inch lcd, because they are all the same resolution is the 17 inchers, which makes the picture not too good IMO
xtknight
12,974
Originally posted by: Nextman916
You dont like your VP930b xtnight?
Well, it's fine, but I'm not that thrilled with ViewSonic in general (not responding whatsoever to three of my e-mails, shady advertising practices in the past, false advertising now (VP930b will not input 720p)). Plus apparently the VP930b has an electronics issue which causes noise in the colors. ViewSonic hasn't fixed it yet AFAIK and it's been an issue for quite a while. The OSD isn't as good as my old Samsung's, and the DVI/VGA notices every input/resolution are annoying and not disable-able. Contrast adjustments are abysmal with color shifts, same problem with R/G/B component adjustment.
Worse backlight bleeding is present. Default gamma was not that great and looked washed out. Plus after a power outage the thing showed theft deterrent and that message wouldn't go away until I found out myself how to hard-reset it. Another user also had the same issue. The calibration software that came on the CD hard-locked my Windows. When enabling ClearType, color fringing is obvious even after ClearType gamma adjustment. This was solved by calibrating colors to match my CRT. But the color fidelity and contrast itself is very good compared to my Samsung 710T TN. Response time is also better (in 80% of cases). The credit for those should probably go to AU Optronics for the P-MVA panel though. One good thing is I had no dead pixels, whereas I had 2 on my Samsung if I recall correctly (over time). I paid $450 for both at the time of purchase. But my next monitor(s) will not be ViewSonics. ViewSonic did a very poor job of implementing an otherwise great panel.
kmmatney
4,363
All BenQ panels are made by AU Optronics, AFAIK, since they are both part of the "BenQ Group".
