Which 19 Inch Monitor Best Fits My Description???
Playmaker
I have done some searches, read some reviews, and looked at various monitors (the ones Best Buy had anyway), but I still can't decide on one to get. I'd like a flat screen 19 inch that will be used mainly for gaming with some web design, browsing, etc. tossed in. I'd like to spend around $300, give or take a little. I'd like the monitor to have a good picture and last awhile. I don't think I'd run more then 1280x1024@85hz, so doing 1600x1200 is not necessary. I've looked at the Hitachi CM715 and the NEC Accusync 90 and 95f, and like the looks of both of them. What do the rest of you think about these monitors? Any info you could give me or maybe another monitor I should consider? Thanks in advance.
My choices would be the Samsung SyncMaster 955DF and the NEC AccuSync 95F, they both use the same Samsung DynaFlat tube. Another good one for under $300 would be the NEC MultiSync FE950.
