Where's a cheap and reliable place to get an oil change?
I heard horror stories of Jiffy Lube. I've been getting mine at Econo Lube N' Tune but their prices depend on the location and one time they broke my hood so it wouldn't open (ended up costing me well over $200 to fix).
your driveway.
otherwise ymmv.
I use walmart they are cheap, and offer Mobile1 changes but, slow.
Sometimes I use the local Mobile gasstation with drivethrough oilchange, Mobile 1.
You can use the other drive through places, just stand out front and watch them... at the end they should say filter tight, oil checked ok, etc confirming all is good and you can see them doing that. And you watch them do the change stuff too.
do it yourself. its easy and cheap.
if you dont want to. check walmart they charge like $15 for a oil change.
a local car dealership charges $9.99 for it. so you might check around.
Do it yourself. It's ten minutes of work, will cost you <$10, you don't have to wait at a shop, and you can do it whenever you want instead of when the place is open.
Seriously - even if it's cold out it's only a few minutes. Many newer vehicles sit higher off the ground so you don't even have to lift them up at all.
Of course I assume that you're able-bodied...
Originally posted by: KK
Walmart or Roger's
KK
Definitely go to Rogers house.........Hell, we should all go. I know he'd be happy to see us and he would probably let us stay for acouple of weeks
I don't know jack about cars, to be honest. I've considered doing it myself many times but I always end up going to some place to get it done instead.
Maybe I'll try WalMart.
You don't have to know anything about cars to change your oil. Your owners manual will tell you how much oil your engine takes. Have a friend or something show you sometime. It's much easier and cheaper to do it yourself.
Until you learn, I vote Walmart.
my garage. I bought a device from kragen that allows me to simply screw a hose into a modified oil drain nut. No more dropping the nut in the pan.
Made by Fram?
Be careful - those are quickly becoming notorious...
Oil change
Oil Change instructions for Women:
1) Pull up to Jiffy Lube when the mileage reaches 3000 miles since the last
oil change.
2) Drink a cup of coffee.
3) 15 minutes later, write a check and leave with a properly maintained
vehicle.
Money spent:
Oil Change $20.00
Coffee $1.00
Total $21.00
Oil Change instructions for Men:
1) Wait until Saturday, drive to auto parts store and buy a case of oil,
filter, kitty litter, hand cleaner and a scented tree, write a check for
$50.00..
2) Stop by 7 - 11 and buy a case of beer, write a check for $20....00, drive
home.
3) Open a beer and drink it.
4) Jack car up. Spend 30 minutes looking for jack stands.
5) Find jack stands under kid's pedal car.
6) In frustration, open another beer and drink it.
7) Place drain pan under engine.
8) Look for 9/16 box end wrench.
9) Give up and use crescent wrench.
10) Unscrew drain plug.
11) Drop drain plug in pan of hot oil: splash hot oil on you in process.
Cuss.
12) Crawl out from under car to wipe hot oil off of face and arms. Throw
kitty litter on spilled oil.
13) Have another beer while watching oil drain.
14) Spend 30 minutes looking for oil filter wrench.
15) Give up; crawl under car and hammer a screwdriver through oil filter and
twist off.
16) Crawl out from under car with dripping oil filter splashing oil
everywhere from holes. Cleverly hide old oil filter among trash in trash can
to avoid environmental penalties. Drink a beer.
17) Buddy shows up; finish case of beer with him. Decide to finish oil
change tomorrow so you can go see his new garage door opener.
18) Sunday: Skip church because I gotta finish the oil change. Drag pan full
of old oil out from underneath car. Cleverly dump oil in hole in back yard
instead of taking it back to Kragen to recycle.
19) Throw kitty litter on oil spilled during step 18.
20) Beer? No, drank it all yesterday.
21) Walk to 7-11; buy beer. Write a check for $20.00.
22) Install new oil filter making sure to apply a thin coat of oil to gasket
surface.
23) Dump first quart of fresh oil into engine.
24) Remember drain plug from step 11.
25) Hurry to find drain plug in drain pan.
26) Remember that the used oil is buried in a hole in the back yard, along
with drain plug.
27) Drink beer.
28) Shovel out hole and sift oily mud for drain plug. Re-shovel oily dirt
into hole. Steal sand from kids sandbox to cleverly cover oily patch of
ground and avoid environmental penalties. Wash drain plug in lawnmower gas.
29) Discover that first quart of fresh oil is now on the floor. Throw kitty
litter on oil spill.
30) Drink beer.
31) Crawl under car getting kitty litter into eyes. Wipe eyes with oily rag
used to clean drain plug. Slip with stupid crescent wrench tightening drain
plug and bang knuckles on frame.
32) Bang head on floorboards in reaction to step 31.
33) Begin cussing fit.
34) Throw stupid crescent wrench.
35) Cuss for additional 10 minutes because wrench hit Miss December (1992)
in the left boob.
36) Beer.
37) Clean up hands and forehead and bandage as required to stop blood flow.
38) Beer.
39) Beer.
40) Dump in five fresh quarts of oil.
41) Beer.
42) Lower car from jack stands.
43) Accidentally crush remaining case of new motor oil.
44) Move car back to apply more kitty litter to fresh oil spilled during
steps 23 - 43.
45) Beer.
46) Test drive car.
47) Get pulled over: arrested for driving under the influence.
48) Car gets impounded.
49) Call loving wife, make bail.
50) 12 hours later, get car from impound yard.
Money spent:
Parts $50.00
DUI $2500.00
Impound fee $75.00
Bail $1500.00
Beer $40.00
Total-- $4165.00
But, you know the job was done right.
Originally posted by: redly1
Originally posted by: minendo
I pay $9.99 at my local Firestone dealer.
Ewww, I've been ripped off too many times by Firestone stores.
EDIT: OMFG, that;'s great, ergeorge
Wish I could claim full credit for it ... one of the few truly hilarious things I've gotten from my my email forwarding friends.
I still laugh out loud every time I read it.
(aka BUMP)
Wal-Mart
i don't change it myself anymore, getting rid of the old oil is a PITA
back in the good ole days when you could just pour it out on the ground or burn it , DIY was fine
