Where & what HDTV card?
HendrixFan
4,646
The only one I know of is the Hauppauge WinTV-HD card foundhere.
It runs at $400, and only one station transmits in HDTV in my area, so Im personally holding off on that card until HD broadcast are more widespread and the card drops in price.
Jeraden
I'd recommend the Hipix. The Hauppauge one is considered crap and not really even in the running. Both the Hipix and AccessDTV have advantages and disadvantages. I got the Hipix, mainly because its open-source, meaning probably better support in the future, plus you can directly convert the saved Hi-Def videos to other formats. The main disadvantage to the Hipix is that you can't run it in a window - full screen only (via vga passthrough cable).
