Where to read codes on 1995 Eagle Vision Esi?
Status
Not open for further replies.
CurseTheSky
5,401
My girlfriend has a 1995 Eagle Vision ESI, and the check engine light has been staying on regularly.
We have an OBD II code reader, but we're not sure where (or if there is) the connection for it. I tried Googling, but I can't find anything.
Anyone happen to know, or able to find any answers to this?
Thanks.
CrackRabbit
16,642
62
Not 100% sure this will work but it's worth a try.
On most Chrysler cars you can flick the key back and forth between off and on (3-4 times) and the computer will display the code either by flashing the Check Engine light or output it on the digital odometer if equipped.
CurseTheSky
5,401
Going to give that a try - thanks!
Farang
10,913
Did you check near the fuse box under the hood? A service manual would tell you, sounds like you'll need one anyway.
CurseTheSky
5,401
The on-off-on-off-on / wait for 5 seconds key method worked perfectly. Thanks again for the advice!
Status
