Hi all,
I've built now a few systems and this is driving me nuts. On my boards I only have two of the 3 pin connectors that you can plug in fans. One is for the CPU fan. which I connect of course.
Then in the manual it states the other is for the case fan. However the case fans I have in all these systems are all 120mm ones and have a regular Molex connection that I connect to the ones that from the PS that say FAN ONLY or if I want them to spin at full speed I connect them to a regular one. The Power Supply also has a lead that happens to be a 3pin one? THUS where does the lead from the PS connect to and what is that for? Will it slow the fan down from the PS? Bahhh. I wish boards would have 3 or 4 of these connectors. Are fans connected to these onboard connectors the only ones that are controlled speed wise for temperature or also the molex ones?
Thanks
Thanks
