where to go online, for water cooling gear
ArkAoss
Banned
Aug 31, 2000
5,437
I'm extremely tempted to try water cooling my next pc, and would like suggestion's on where to go to buy water blocks, radiator's and peltier clamps.
Nastimus
114
DangerDen Have some really good water blocks and a nice radiator
OCWC Has some interesting stuff there.
Overclockers Some good water cooling info look for the link towards the bottom.
Some other places also but I wouldn't go with any of them kits. Also make sure you get copper. Don't get a aluminum water block or radiator or resevoir.
Muerto
1,937
Another vote for the Aquastelth system at 2CoolTek. For $125 you get the water block, pump, radiator, tubing, 120mm fan, reservoir.
Check it out here. There's also a lot of other stuff for extreme cooling. Have fun. :)
sitka
895
I've been slowly putting together a water system and the final piece of the puzzle just showed itself. I really wanted a heatsink on top of the cooler in case the pump went down. "Becooling" has a nice plain high profile sink for 5.99. Of course you need a block with the nipples on the side.
