Where to get fan silencing grommets?
Loki1
111
Does anyone know where I can buy those rubber grommets that you can put in between a fan and the case to make it less noisy? I seen some online but I thought maybe someone would know where to get some at a local hardware store maybe?
suszterpatt
927
Looking at the Vantec package, it says not to use the dampener and the provided screw washers together. Why is that?
JBDan
2,333
I'm not familiar with Vantecs package. I'm guessing that with the washers in addition to the dampener, the rubber screws will not be long enough to hold?? Just a guess. I used the ones like from jab tech and they work great.
Bona Fide
Banned
Jun 21, 2005
1,901
The Jab-tech ones look exactly like the ones on my friend's P160. I would recommend them because he told me his do wonders for silencing and minimizing vibration.
Zepper
18,998
I noticed that on the Vantec pack but I went ahead and used the washers anyway. I guess you should try some local experimentation. One of those mechanic's stethoscopes with the contact probe on it would help in judging comparative noise levels as the diff is likely to be slight. First try it without the washers and see what the noise level is and then add the washers and see if there is any difference. I just went on the idea that the more you can isolate from contacting the case, the better for reducing noise transmission.
. I also got some of those Sunbeam rubber fan pins from jab-tech but I noticed that those leave a small gap between the fan and the case that could set up for a whistling noise. I suppose I could run a string of rope caulk around the edge of the fan to take care of that should it occur.
.bh.
glorygunk
805
don't waste your money buying official case mod stuff
i picked up a bunch from a local hardware store for a dime a piece.
Cerb
17,484
33
86
If you're still screwing into the case, the difference won't be enough to justify the cost. SPCR forums have many creative solutions that will work great, and some are even easy to implement :).
The Verax and EAR mounts are good, but flimsy (they are for absorbing/isolating, after all...), and don't allow a seal.
EAR:
http://www.endpcnoise.com/cgi-bin/e/Fanisolators.html?id=hqQGVCuW
Verax (I couldn't find a place selling them off-hand):
http://www.silentpcreview.com/files/images/spcr_lab/spcr_lab12.jpg
Operandi
Soft mounting your fans is one of the last steps to be taken. You're system has to have an already very low noise floor for method of mounting to make any difference. If your fans run at more then 1200RPM it's probably not worth it.
Having said that the Vantec gaskets are pretty useless, the EAR mounts are the best option.
Aug 27, 2002
10,043
I beg to differ, high rpm fans that are poorly balanced benifit a good deal from silicon mounts. but I will agree, dollar for dollar it would be best to just get better fans.
and ear mounts are excellent
Operandi
"High RPM, poorly balanced" fans will be loud regardless.
Start with slow well balanced fans; if it's still too loud then you can soft mount them.
