I am in the process of putting a 120mm fan on the side of my case. At first I was thinking of getting a hole saw for a drill but realized that it costs around $25-$30. After seeing that I figured I could get a dremel, pay a little more, but be able to use it for other things. I will probably install a 92mm or 80mm in the front of my case soon as well. I think I saw a Dremel tool kit for around $45 but it was the single speed kit rather than the multi-speed kit which was around $80. Is this single speed kit fine? Also anyone got a link to some sites on the internet that sell these kits. Finally, which tool bits will i need to cut blowholes and sand the edges?
Thanks in advance.
Thanks in advance.
