Originally posted by: Eli
It really is not very hard. Anybody that has ever so much as looked at a wrench before should be able to do it.
Although it would help if we knew what kind of car you have. It is certainly easier on some than others.
Run to the store and buy a drain pan, an oil filter wrench, a new oil filter, your oil, and if you need it.. a socket set. Should run you less than 30$, and you'll always be able to do it yourself in the future.
Going to the store will warm your engine up. Always change your oil with the engine warm. Now comes the fun part.
Put some clothes on that you don't care about.. Bring an extra old t-shirt as a rag. Shimmy under your car, and position your drain pan. Find your oil pan and unscrew the drain bolt. Let the oil drain..
Unscrew your filter. You honestly may not even need the filter wrench. Wipe the oil filter mounting place clean. Dip your finger in a new quart of oil, and coat the oil filter gasket with fresh clean oil, and screw it home. Make sure it's nice and snug.
Screw the drain plug back in, and add your fresh oil. Congratulations! It will take you about 45 minutes since you have never done it before.
If you really don't want to deal with it, just take it to Jiffy Lube. Of course, it depends.. but maybe you'll be lucky and get someone that actually knows more than you do about changing your oil. 😉
