While I was on vacation, the PSU in my secondary system went belly up, and took out my GA-K8NSC-939 Mobo with it. I finally got a Foxconn Winfast 6150K8MA board to replace it, and it seems to be well. All except for one small detail.
The case I have has a 3 pin connector for the Power LED, which was fine on the K8NSC Mobo. However, the new Mobo P-LED is a 2 pin port, next to each other.
Does anyone know if/where I can get an adapter that has a 2 pin female plug on one side, that will go to a 3 pin male on the other so I can plug my power LED cable in?
Thanks.
Thanks.
