where to get 16 inch eps12v 24 pin, 8 pin, 4 pin extensions?
imported_Kirika
7
i got a double case here http://forums.2cpu.com/showthread.php?t=77273
and the power supply is located on oneside with the motherboard on the other. I need eps12v 24 pin 8 pin and 4 pin extenders but the ones i found online are only 12 inch and would come from ca or florida and that might not quite be enough would have to get multiple ones, anyone know where to get longer ones preferably locally but might have to order online
Zepper
18,998
IDK if making your own would be an option for you. http://www.action-electronics.com has the connectors, http://www.bgmicro.com has the wire and http://www.jab-tech.com has a really nice crimping tool. But for the best result, I suggest cutting and splicing. All you need for that is wire, solder, soldering iron and heatshrink tubing. Once again, http://www.bgmicro.com has the 18 ga. wire on spools and soldering equipment and supplies - can't remember whether they offer the heatshrink or not..
.bh.
