Where to find ASPI for win2k (problem inside)
Rooster286
I cant seem to locate it anywhere.
Whenever I load CDRWIN it asks for ASPI Manager to be installed, same happens with Nero and Clone CD.
I just reinstalled Win2k, and the previous install never had this problem, can anyone help????
Thanks!
There is no ASPI layer in Windows 2000, it is loaded by your software for Burners and the like, many times it installs incorrectly. Check your layer with this toolAspiChk and then fix it with this tool,ForceAspi I have used both, they work great for win2k, clears up a lot of burner,DVD and CD problems
Edit: I see you have it fixed!
I think EzCD Creator 4.0 installed it last time, but 5.0 Platnium doesnt have the ASPI install file on it anymore, perhaps they dont use it??
