Where to buy fuses? (Other than Radio Shack or Home Depot)
BD2003
I need to get a new fuse for my Z560s. Radio shack doesnt have the size I need, and neither does the home depot. Theyre really tiny.
Where can I pick up fuses locally or online? The faster I can get it the better, I need sound.
BD2003
Cant use auto fuses.
And not having fuses is a drawback, fool. I'd rather have blown fuses than blown speakers.
Zim Hosein
Super Moderator | Elite Member
65,205
400
<< Auto parts store >>
You can also get fuses from this online retailer: http://mcmelectronics.com/welcome.jhtml , if I remember correctly, the fuses are found under "Automotive Installation." Hope this helps :)
<< Cant use auto fuses. >>
Why? :confused:
BD2003
The one I need is totally different looking from auto fuses. Its a small glass tube.
They have them at radio shack, just not the exact combination of Size, Amps and Volts that I need.
I called up logitech, and they said go to radio shack. They say they dont have them. I'm really not in the mood to ship everything back for a damn fuse.
Zim Hosein
65,205
400
<< The one I need is totally different looking from auto fuses. Its a small glass tube. >>
This type of fuse can be found at auto parts stores, they are pretty common in car audio installs. If you local auto parts store doesn't have them, try a store/shop that deals w/ car audio. What are the markings on the fuse?
BD2003
I actually have those very fuses in front of me. Too big.
The ones I need are one size smaller, although I dont know exactly what that measures out to.
The guy from the logitech said to use a 4A 125V (saw some at RS) that fits, and to keep the sub turned down until I find a proper one. Otherwise he said to send the whole thing back for warranty repair. Good or bad idea?
Zim Hosein
65,205
400
BigDee2003, maybe someone here who has the z560's could tell us where the replacement fuses are available :confused:
JW310
1,582
I second going to your local auto parts store. Back when I put a mobile amateur radio in my car, I used the glass tube type fuses inline with the power connector. They had all varieties of sizes and amperages in stock. It's at least worth a shot to go and look.
JW
BD2003
No luck finding them online so far, but I dont really know where to look.
Anyone know the next smallest size below 1-1/4x1/4 for glass tube fuses?
I could pick up either a 5A 250V or a 4A 125V that would fit from radio shack. Would either one work, or are both bad ideas?
element2k5
683
shouldnt ur surge protector handle the fuse situation??? i am suprised that they still have fuses in the speakers.... cause most surge protectors have built in circuit breakers in them
BD2003
Nothing else on the surge protector fried. Wasnt from a power surge, it was a static shock that blew the fuse out. Long story.
BD2003
Can I exchange ceramic fuses with glass fuses? The guy on the phone said it needed to be a slow-blow fuse.
sharkeeper
10,886
When I was a kid people used to replace fuses in their house with a penny. Then the house caught fire! :Q
Cheers!
Evadman
Administrator Emeritus<br>Elite Member
Feb 18, 2001
30,990
As long as the amperage is the same rating for your application, the voltage does nto matter. The voltage is just a rating on how much the glass / insulator is rated for. a 4A 12v will blow at 5a just as a 4A 240v will blow at 5a. The voltage means nothing to a fuse, they only control amperage.
Evadman
Feb 18, 2001
30,990
That is the rating of the insulator. If you use a 120v in a 240v application, the fuse can leak. Just make sure to get one higher rated than your application.
<edit> oh, and a slow-blo is a fuse that is rated @ 4a, but can take 5-6 for a second or 2 and not blow. Fuses are basicly made to prevent direct unfused grounds . Those start fires and damage circutry. if a device pulls 4a, it can usually handle a certan amount of overage for a few seconds without any damage. ( depends on the unit / quality ) In that case, a slow-blo fuse is used.
