Where to buy a Fong-Kai 320 without power supply
Jumpem
10,757
I want a black FK 320. I'm going to put an Enermax power supply in it, so I don't need one included. Thanks!
Jhhnn
IN MEMORIAM
Nov 11, 1999
62,365
14,685
For the money, I'd just buy the standard package from Directron, purchase an Enermax separately. Keep the very solid 300w Enhance as a spare or sell it off cheap to an underpowered friend..
flyers1
1,233
I got my FK-320 from directron also. I skipped the P/S (since I already had a 330W enermax) and used the extra cash towards a 120mm Panaflo L1A for the front of the case. It's an awesome fan that moves alot of air and is very quiet. You may want to replace the stock rear 92mm fan also if you don't like much noise.
rondeemc
1,216
Also the rear fan seems to be set as an intake instead of an exhaust as recommended by AMD.
rondeemc
1,216
Actually directron.com sells the Enermax line so just trade in the factory PS for the enermax and have them install it for you
Jhhnn
IN MEMORIAM
Nov 11, 1999
62,365
14,685
At $98 for the case+psu, and $86 for the case alone, they're practically stealing really good 300w Enhance psu's, with the buyers' permission, of course. They want $43 for the same unit!
Like I said before, for $12 I'd definitely keep it.
Wingznut
16,968
You are right rondeemc. That was the first thing that I did, was turn that rear fan around so that it exhausted air.
