Where the heck is the HD LED connection on this P4B266-C mobo?!
JackBurton
15,993
14
WTH? Are they hiding it from me or something? It's not in the cluster where the power sw, reset sw, power LED and all the other stuff is. Someone with this board PLEASE tell me where Asus hid it. I read the manual and can't find it anywhere! :|
Pabster
16,986
LOL, I thought the same thing when I got my first P4B266-C :D
It's actually a separate 2-pin connector, an inch or so above the main switch blocks. It is in the manual, but not in logical order. You're also likely to connect it the wrong way the first time. So if it doesn't light up, reverse the polarity ;)
John
Moderator Emeritus<br>Elite Member
4
Did you check you manual? page 2-24
It's right above the dipswitch block. :)
JackBurton
15,993
14
OK guys, THANKS ALOT! WTH is up with that? The next thing you know they are going to scatter all the connections all over the board! :|Thanks again guys! :)
