where should i put my drive
dshodson
484
i just got a new 120 gig drive (the WD with the 8 meg buffer)
i already have two 60gigs in a raid config
im thinking of just adding this as an ide since id either have to buy another one or change my raid config
i have an asus a7v133 mb and the primary ides are currently my dvd and the other primary is for my cdrw
where should i put my new drive for optimal performance (assuming that im not going to buy another 120gig to have both in the raid)
should i put is a secondary or should i put the dvd or cdrw on as a secondary
D
Willoughbyva
3,267
I don't think it should really matter. Just make sure that you have the boot order right in the bios. (which you probably do already) Assuming you will be booting off of your raid controller.
