Where is the best place to find a...
DeathSlayer
161
Originally posted by: ribbon13
Originally posted by: DeathSlayer
the main problem for me: the MB i have is small enough to fit into a small OEM case. so i can't get a new MB, thats for sure.
For $400 you could easily get a new motherboard case and powersupply and be able to keep the rest. oh wait.. you have a 480w decent PSU? oh so that makes it just motherboard and case.
yeah, but if i do that, i guarantee you i will end up upgrading my whole PC, not just my video, which is the exact opposite i want to do. I want to have the best possible AGP config in my pc, which i am performing now.
DanDaMan315
1,366
Yea just get the card, its a good deal anyway.
DeathSlayer
161
is there any way to OC your ram besides the BIOS? my BIOS doesn't have an option :(!
Mr. W, if you are reading this, i have a PM for you ;)
cmge
110
so bang for the bukc x850xt > x850xt pe since u can o/c the x850xt to pe speeds??.. and stock cooling is sufficient??
will it pose a prob say if u have your rig on 24/7 and the x850xt is o/cd at pe speeds?
ElFenix
102,402
8,574
the 850xt is going to be so cpu limited by that AXP...
GamerExpress
Banned
Aug 28, 2005
1,674
I have a 480W beast.
oh, and also, are you sure they (and every other place like newegg) are getting more units in? i will be dissapointed if i miss out on the very last batch of X850XTPE AGPs in existance (like the ones on amazon and ebay)
What brand?
