Where is setting for AGP speed?
dublinman
I have an older Asus GeForce 2 GTS 32 Mg AGP card that is supposed to be able to Run at AGP4X speed. I'm running an Asus A7V133 Motherboard and I'm running the Detonator drivers for the Card.
When I pull up Display Properties, Geforce 2 GTS Tab, under Adapter info it shows "Bus AGP1X".
Is this correct?, is there another way to verify that the card is running at 1X or 4X? I dont see a setting for AGP speed on Display properties. I have looked at the bios and have set up the following;
Under Chip configuration, AGP 4X drive strength-[auto],AGP 4X mode -[4X], AGP Fast write-[enabled]. I don't see any other settings related to this. Any advice would be helpfull either for settings or to verify AGP speed.
Thanks.
Run DXDIAG and see if AGP Texture Acceleration is enabled. If it is grayed out, you may have to install Via's 4-in-1 drivers.
Thanks for the response, I went to DXdiag and AGP Textures was enabled, I'm also using lastest version of 4in1 Via drivers as well as latest Detonator drivers. Any other ideas as to how to determine what AGP speed card is running at or do you think the AGP1X speed reported by display properties is accurate?
Thanks again.
last time i used Sisoft SANDRA, i remembered it has a module to analyze your AGP port and video specs. you can download the trail version for free.
